When I use the module "File Write Text File" (it's a native script), I connect the "folder" inlet to a custom path name which is "dynamic" (it depends on the date). But I noticed that since the folder does not exist, the script cannot create a text file accordingly.
Is there a way to create the right folder at the right path (defined by the "folder" inlet) before creating the text file, please?
By the way, I take advantage of this thread to ask you if there is a way to enter a simple "space" character in a concat string inlet? (in the meantime I use an underscore character but it's not convenient). More generally, out of curiosity, what about other Unicode characters?
creal.
Create folder via the script "File Write Text File"
hello,
you can use the procedure
to create a directory as referenced in https://www.brainmodular.com/manuals/hh4/en/scripting
The best way to have a 'space' in the concat module is to connect a constant module with the value 32. It's the ascii code for 'space'.
Code: Select all
procedure CreateDir(dir:String);The best way to have a 'space' in the concat module is to connect a constant module with the value 32. It's the ascii code for 'space'.
thank you very much.
I tested some things with this procedure. For the moment, it didn't find how to add it to the current code. But I don't give up.
Excellent for the ASCII characters. It works like a charm.
creal.
creal.
