Creating patches with front & back panels (how can I change a modular wire opacity?)
eartubes
Unread post by eartubes » 21 Nov 2020, 16:39
I am trying to create patches that represent a device that has both a front facing and back facing panel, similar to Reason's Rack, that can be flipped around and you can reroute signals with cables.
I toggle front/back switching pressing Z on the keyboard.
When I hide both modular inputs, the wire remains, and there is no reference that I can see to change that wire's opacity, except in the setup modular settings, but I am unsure how to access this variable.
How can I fix this, or is there a better way to implement this?
Also I notice when I open the workspace fresh, there is a visual glitch?? pressing Z fixes it.
front-back-devices.wkp
(97.93 KiB) Downloaded 273 times
Unread post by nay-seven » 21 Nov 2020, 21:50
There's a module named setup settings where you can link your switch to the inlet wire opacity
eartubes
Unread post by eartubes » 22 Nov 2020, 06:03
beautiful, thanks!
