vst 3 support
seamus
vst 3 support
Unread post by seamus » 12 Nov 2020, 17:07
does hollyhock support vst 3?
It was crashing when i loaded my vst3 plug in folder for scanning when Ableton didnt crash.
Unread post by nay-seven » 12 Nov 2020, 17:39
Yes, most of VST3 are recognized and supported ?
Which version of Usine?
Sometimes it crash, but if you restart and continue the scan it can solve it
seamus
Unread post by seamus » 10 Mar 2021, 17:29
i have a vst3 that works well in ableton live but not in the latest version of hollyhock
Its called respiro. The plugin scans fine but takes an incredibly long time to open in hollyhock. ANy ideas why this can happen? probably there is no workaround or solution?
Unread post by senso » 10 Mar 2021, 17:57
please send a report to support@brainmodular.com, we will take a look.
seamus
Unread post by seamus » 11 Mar 2021, 17:13
I wonder if there is a way to test this plugin with hollyhock. Maybe i can ask the developer to give you a license for Respiro so you can try it? Hollyhock is not able to handle it. here is the activity log from the last attempt to use it. It just kind of freezes the machine and i get cpu overload warnings.
[4:34:19 PM] Application path : C:\music production\Usine HH4 Win64 4.1.201213
[4:34:19 PM] Modules path : C:\music production\Usine HH4 Win64 4.1.201213\Resources\Modules
[4:34:19 PM] Usine-full 4.1.201213 WIN64
[4:34:19 PM] CPUCount : 12
[4:34:19 PM] SSE3 Activated
[4:34:19 PM] OS Version : Windows 10 (Version 10.0, Build 19041, 64-bit Edition)
[4:34:19 PM] Name : Windows 10
[4:34:19 PM] Major : 10
[4:34:19 PM] Minor : 0
[4:34:19 PM] Build : 19041
[4:34:19 PM] Canvas:TCanvasGpu
[4:34:19 PM] Hardware acceleration:0
[4:34:19 PM] Screen Resolution:1920x1080
[4:34:19 PM] Screen scale:1
[4:34:19 PM] Param string 0:C:\music production\Usine HH4 Win64 4.1.201213\Bin\Usine.exe
[4:34:19 PM] Param string 1:
[4:34:19 PM] Critical Sections created
[4:34:22 PM] Messages Handlers created
[4:34:22 PM] Load Color Set
[4:34:22 PM] Colors loaded
[4:34:22 PM] Initialization Mix
[4:34:22 PM] Initialization av_codec
[4:34:22 PM] Initialization av_codec done
[4:34:22 PM] start process language
[4:34:22 PM] Load Translator en
[4:34:22 PM] create LocateBox
[4:34:22 PM] start ReadAllImagesList
[4:34:22 PM] end ReadAllImagesList
[4:34:22 PM] start ReadAllMediaFilesList
[4:34:22 PM] end ReadAllMediaFilesList
[4:34:22 PM] start ReadAllPackageFilesList
[4:34:22 PM] end ReadAllPackageFilesList
[4:34:22 PM] start LoadRenamedFile
[4:34:22 PM] end LoadRenamedFile
[4:34:22 PM] locatefile created
[4:34:22 PM] recent files loaded
[4:34:22 PM] initialization Usine done
[4:34:22 PM] main menu created
[4:34:22 PM] console created
[4:34:22 PM] network manager created
[4:34:22 PM] top header created
[4:34:22 PM] setup panel created
[4:34:22 PM] ArtNetDMXManager created
[4:34:22 PM] colors form created
[4:34:22 PM] poubelle panel created
[4:34:22 PM] menu left created
[4:34:22 PM] patch main panel created
[4:34:22 PM] master panel created
[4:34:22 PM] global synchro created
[4:34:22 PM] remote panel created
[4:34:22 PM] toolbox panel created
[4:34:23 PM] devices panel created
[4:34:23 PM] Binds panel created
[4:34:23 PM] trace panel created
[4:34:23 PM] settings panel created
[4:34:23 PM] Grid New Panel created
[4:34:23 PM] Splitter Grid created
[4:34:23 PM] Scroller design created
[4:34:23 PM] Design Panel created
[4:34:23 PM] IB Panel created
[4:34:23 PM] SyntheticViewPanel Panel created
[4:34:23 PM] Mixer Panel created
[4:34:23 PM] Plot Panel created
[4:34:23 PM] Workspace Panel created
[4:34:23 PM] browser panel createpanel start
[4:34:23 PM] browser panel created
[4:34:23 PM] playlist panel created
[4:34:23 PM] directtodisk panel created
[4:34:23 PM] splitter patch created
[4:34:23 PM] contextual menu panel created
[4:34:25 PM] templates panel created
[4:34:25 PM] quantize panel created
[4:34:25 PM] draghint panel created
[4:34:25 PM] DragHint created
[4:34:25 PM] convoler panel created
[4:34:25 PM] start LoadUsine
[4:34:25 PM] Load User Module : DeviceAudio_4.0_2.usr-win64
[4:34:25 PM] [audio] --checkAudioDrivers--
[4:34:25 PM] [audio] deviceManager.getAvailableDeviceTypes
[4:34:26 PM] [audio] num devices type: 4
[4:34:26 PM] [audio] found devices type: Windows Audio
[4:34:26 PM] [audio] found devices type: Windows Audio (Exclusive Mode)
[4:34:26 PM] [audio] found devices type: DirectSound
[4:34:26 PM] [audio] found devices type: ASIO
[4:34:26 PM] [audio] --getAudioSampleRatesList--
[4:34:26 PM] Load User Module : DeviceDMX_2.0_02.usr-win64
[4:34:26 PM] Error : Create procedure failed in :DeviceDMX_2.0_02
[4:34:26 PM] Load User Module : DeviceMidi_2.0_07.usr-win64
[4:34:26 PM] begin rescan midi devices
[4:34:26 PM] finish rescan midi devices
[4:34:26 PM] Load User Module : PluginLister_3.0_02.usr-win64
[4:34:26 PM] [audio] --updateParamsVisibility--
[4:34:26 PM] [audio] indexSelectedDeviceDriver 3
[4:34:26 PM] [audio] CALLBACK m_ledAudioDeviceInputNames CHANGED received
[4:34:26 PM] [audio] CALLBACK m_ledAudioDeviceOutputNames CHANGED received
[4:34:26 PM] [audio] CALLBACK m_ledSetupLoaded CHANGED received
[4:34:26 PM] [audio] --applyDevice--
[4:34:26 PM] [audio] driver index: 3
[4:34:26 PM] [audio] indexSelectedDeviceDriver: 3
[4:34:26 PM] [audio] --checkAudioDrivers--
[4:34:26 PM] [audio] deviceManager.getAvailableDeviceTypes
[4:34:26 PM] [audio] --audioDeviceStopped--
[4:34:26 PM] [audio] --changeDriverSettings--
[4:34:26 PM] [audio] --traceAudioSetup--
[4:34:26 PM] [audio] in device: Primary Sound Capture Driver
[4:34:26 PM] [audio] channels: 0000000000000011
[4:34:26 PM] [audio] out device: Primary Sound Driver
[4:34:26 PM] [audio] channels 0000000000000011
[4:34:26 PM] [audio] buffer size: 0
[4:34:26 PM] [audio] samplerate: 44100
[4:34:26 PM] LoadData User Module : DeviceAudio_4.0_2
[4:34:26 PM] LoadChunk User Module : DeviceAudio_4.0_2
[4:34:26 PM] LoadData User Module : DeviceDMX_2.0_02
[4:34:26 PM] LoadData User Module : DeviceMidi_2.0_07
[4:34:26 PM] LoadChunk User Module : DeviceMidi_2.0_07
[4:34:27 PM] LoadData User Module : PluginLister_3.0_02
[4:34:27 PM] [audio] CALLBACK MSG_CHANGE_DRIVERS_REQUEST received
[4:34:27 PM] [audio] --checkAudioDrivers--
[4:34:27 PM] [audio] deviceManager.getAvailableDeviceTypes
[4:34:27 PM] [audio] --audioDeviceStopped--
[4:34:27 PM] [audio] num devices type: 4
[4:34:27 PM] [audio] found devices type: Windows Audio
[4:34:27 PM] [audio] found devices type: Windows Audio (Exclusive Mode)
[4:34:27 PM] [audio] found devices type: DirectSound
[4:34:27 PM] [audio] found devices type: ASIO
[4:34:27 PM] [audio] --changeDriverSettings--
[4:34:27 PM] [audio] --traceAudioSetup--
[4:34:27 PM] [audio] in device: Microphone (Realtek(R) Audio)
[4:34:27 PM] [audio] channels: 0000000000000011
[4:34:27 PM] [audio] out device: Primary Sound Driver
[4:34:27 PM] [audio] channels 0000000000000011
[4:34:27 PM] [audio] buffer size: 64
[4:34:27 PM] [audio] samplerate: 44100
[4:34:27 PM] Load Color Set
[4:34:27 PM] ServerStoreIPaddress fails
[4:34:27 PM] [audio] CALLBACK m_lboxDeviceDrivers CHANGED received
[4:34:27 PM] [audio] --updateDevicesDriversCaptions--
[4:34:27 PM] [audio] --updateParamsVisibility--
[4:34:27 PM] [audio] indexSelectedDeviceDriver 4
[4:34:27 PM] [audio] --applyDevice--
[4:34:27 PM] [audio] driver index: 4
[4:34:27 PM] [audio] indexSelectedDeviceDriver: 4
[4:34:29 PM] [audio] --checkAudioDrivers--
[4:34:29 PM] [audio] deviceManager.getAvailableDeviceTypes
[4:34:29 PM] [audio] --audioDeviceStopped--
[4:34:29 PM] [audio] num devices type: 4
[4:34:29 PM] [audio] found devices type: Windows Audio
[4:34:29 PM] [audio] found devices type: Windows Audio (Exclusive Mode)
[4:34:29 PM] [audio] found devices type: DirectSound
[4:34:29 PM] [audio] found devices type: ASIO
[4:34:29 PM] [audio] --changeDriverSettings--
[4:34:29 PM] [audio] --traceAudioSetup--
[4:34:29 PM] [audio] in device: ASIO4ALL v2
[4:34:29 PM] [audio] channels: 0000000000000011
[4:34:29 PM] [audio] out device: ASIO4ALL v2
[4:34:29 PM] [audio] channels 0000000000000011
[4:34:29 PM] [audio] buffer size: 64
[4:34:29 PM] [audio] samplerate: 44100
[4:34:29 PM] [audio] --updateParamsVisibility--
[4:34:29 PM] [audio] indexSelectedDeviceDriver 4
[4:34:29 PM] [audio] CALLBACK BufferSize CHANGED received
[4:34:29 PM] [audio] --applyDevice--
[4:34:29 PM] [audio] driver index: 4
[4:34:29 PM] [audio] indexSelectedDeviceDriver: 4
[4:34:30 PM] [audio] --audioDeviceStopped--
[4:34:30 PM] [audio] CALLBACK MSG_CHANGE_DRIVERS_REQUEST received
[4:34:30 PM] [audio] --checkAudioDrivers--
[4:34:30 PM] [audio] deviceManager.getAvailableDeviceTypes
[4:34:30 PM] [audio] num devices type: 4
[4:34:30 PM] [audio] found devices type: Windows Audio
[4:34:30 PM] [audio] found devices type: Windows Audio (Exclusive Mode)
[4:34:30 PM] [audio] found devices type: DirectSound
[4:34:30 PM] [audio] found devices type: ASIO
[4:34:30 PM] [audio] --changeDriverSettings--
[4:34:30 PM] [audio] --traceAudioSetup--
[4:34:30 PM] [audio] in device: ASIO4ALL v2
[4:34:30 PM] [audio] channels: 0000000000000011
[4:34:30 PM] [audio] out device: ASIO4ALL v2
[4:34:30 PM] [audio] channels 0000000000000011
[4:34:30 PM] [audio] buffer size: 64
[4:34:30 PM] [audio] samplerate: 44100
[4:34:30 PM] load setup done
[4:34:30 PM] load panels done
[4:34:30 PM] end LoadUsine
[4:34:30 PM] start NotifyUsineLoaded
[4:34:30 PM] end NotifyUsineLoaded
[4:34:30 PM] workspace loaded
[4:34:30 PM] FadeThreader Created
[4:34:30 PM] RealTimeQueue Created
[4:34:30 PM] NetworkUpdateThread created
[4:34:30 PM] DMXUpdateThread created
[4:34:30 PM] presetThread created
[4:34:30 PM] OSCSendThread created
[4:34:30 PM] main menu destroyed
[4:34:30 PM] resize handle OK
[4:34:30 PM] Menu Left created
[4:34:30 PM] start panel created
[4:34:30 PM] start HideDesignPanel
[4:34:30 PM] end HideDesignPanel
[4:34:30 PM] InternetStuffsThreader Created
[4:34:30 PM] check internet connection
[4:34:31 PM] ServerStoreIPaddress ok
[4:34:31 PM] get help index file
[4:35:08 PM] Load User Module : PluginWrapper.usr-win64
[4:35:08 PM] Create user module : C:\music production\Usine HH4 Win64 4.1.201213\Config\Plug-Ins\VST3\Respiro.plugin
[4:35:08 PM] PluginWrapper : start CreateModule
[4:35:08 PM] PluginWrapper : start init juce
[4:35:08 PM] PluginWrapper : end init juce
[4:35:08 PM] PluginWrapper : start create module
[4:35:13 PM] PluginWrapper : end create module
[4:35:13 PM] PluginWrapper : end CreateModule
[4:40:42 PM] LoadData User Module : PluginWrapper Respiro
[4:40:42 PM] LoadChunk User Module : PluginWrapper Respiro
[4:40:42 PM] audioProcessorChanged
[4:40:42 PM] call getPluginWindow
[4:40:42 PM] call new PluginWindow
[4:40:42 PM] call setSize
[4:40:42 PM] call setUsingNativeTitleBar
[4:40:42 PM] call owner_->hasEditor
[4:40:43 PM] call owner_->createEditorIfNeeded
[4:40:43 PM] call ui->setOpaque
[4:40:43 PM] call setContentOwned
[4:40:43 PM] call owner_->getName
[4:40:43 PM] call setVisible
[4:40:43 PM] call toFront
[4:40:43 PM] call sendOnTop
[4:40:43 PM] call grabKeyboardFocus
[4:40:43 PM] call setWantsKeyboardFocus
[4:40:43 PM] call addKeyListener
[4:40:43 PM] call activePluginWindows
[4:40:43 PM] call setTopLeftPosition
[4:40:43 PM] create PluginWindow done
[4:40:43 PM] call getPluginWindow ok
[4:56:43 PM] call getPluginWindow
[4:56:43 PM] call new PluginWindow
[4:56:43 PM] call setSize
[4:56:43 PM] call setUsingNativeTitleBar
[4:56:43 PM] call owner_->hasEditor
[4:56:43 PM] call owner_->createEditorIfNeeded
[4:56:43 PM] call ui->setOpaque
[4:56:43 PM] call setContentOwned
[4:56:43 PM] call owner_->getName
[4:56:43 PM] call setVisible
[4:56:43 PM] call toFront
[4:56:43 PM] call sendOnTop
[4:56:43 PM] call grabKeyboardFocus
[4:56:43 PM] call setWantsKeyboardFocus
[4:56:43 PM] call addKeyListener
[4:56:43 PM] call activePluginWindows
[4:56:43 PM] call setTopLeftPosition
[4:56:43 PM] create PluginWindow done
[4:56:43 PM] call getPluginWindow ok
[4:56:47 PM] call getPluginWindow
[4:56:47 PM] call new PluginWindow
[4:56:47 PM] call setSize
[4:56:47 PM] call setUsingNativeTitleBar
[4:56:47 PM] call owner_->hasEditor
[4:56:47 PM] call owner_->createEditorIfNeeded
[4:56:47 PM] call ui->setOpaque
[4:56:47 PM] call setContentOwned
[4:56:47 PM] call owner_->getName
[4:56:47 PM] call setVisible
[4:56:47 PM] call toFront
[4:56:47 PM] call sendOnTop
[4:56:47 PM] call grabKeyboardFocus
[4:56:47 PM] call setWantsKeyboardFocus
[4:56:47 PM] call addKeyListener
[4:56:47 PM] call activePluginWindows
[4:56:47 PM] call setTopLeftPosition
[4:56:47 PM] create PluginWindow done
[4:56:47 PM] call getPluginWindow ok
[4:58:34 PM] begin rescan midi devices
[4:58:34 PM] finish rescan midi devices
[4:59:48 PM] workspace saved : respiro.wkp
x.iso
Unread post by x.iso » 13 Mar 2021, 16:31
there was similar thing going on with Vital, VST2 version worked fine though.
