latch mode in sampler recorder ?
nbremaud
Unread post by nbremaud » 08 Nov 2020, 11:58
It's really a newbie question but I dare asking it (sorry if i missed something obvious) :
I would like the sampler recorder module to work as follow :
when I press the rec button, i would like the recording to start on the first beat on the next bar (instead of starting when the rec button is pressed).
And same thing for the play loop button.
Please, can someone give a clue about that ?
Unread post by grego mondo » 08 Nov 2020, 14:32
I'd use a switch for rec to activate a pass flow getting a master sync cycle trigger to set on another switch recording
and another switch for play to activate a pass flow getting the master sync cycle trigger (setting off that play switch) to play the sampler.
It's in that
quantized rec & play.pat
(30.92 KiB) Downloaded 313 times
hopping it will do the trick
nbremaud
Unread post by nbremaud » 08 Nov 2020, 16:48
Thanks a lot for the quick help !
I'll try this and tell you if it worked for me.
joffo78
Unread post by joffo78 » 09 Nov 2020, 20:30
Simpler : activate quantize on beat on midi button or switch propriety
nbremaud
Unread post by nbremaud » 10 Nov 2020, 11:38
Thanks joffo 78, it's a lot simpler indeed.
And a big thanks to grego mondo too, your patch works well and, above all, it allowed me to make a big step forward in understanding usine and patches.
Users browsing this forum: No registered users and 107 guests
