Patch Number
percuson
Patch Number
Unread post by percuson » 23 Oct 2020, 17:44
Hi there!
After a long time I am back to Usine. My last version of Usine was Usine 5. and wow, it has evolved...
In Usine 5 there was a module called "current line number". In HH4 I found an inlet "patch number" in the "Load Patch" module. But I didn't find anything that will give me the number of the patch as an output.
I want to create something like a patch ID for remote control.
Thank you!
Unread post by SylvainT » 24 Oct 2020, 16:21
Welcome back,
Yes, indeed, so much improvements since Usine V5.
The workaround was totaly rebuild, so, unfortunately for you, no more current line number. You can find current rack number and have acces to patch with usine patch settings module .
To access to patch position, you can use scripts, but you'll need to deal with scripting langage.
All the best
