list manager clear list
Unread post by cmodica » 28 Sep 2020, 16:22
Hello all.
I use a ListManager with a sampler to load lists of sounds. I put a Pass if Changed between the ListManager and the sampler so that the list is updated each time I add new sounds.
But if I delete the list from the ListManager, it is not deleted in the sampler. I need to make a ClearList in the sampler as well.
Is there a solution for this?
Unread post by nay-seven » 03 Dec 2020, 09:20
Edited:
In the latest version there's a clear list and a clear last in the sampler module ?
Unread post by cmodica » 03 Dec 2020, 09:36
Wonderful ! I will test it.
Unread post by cmodica » 04 Dec 2020, 10:48
I am sorry but i don't understand.
Where is the clear list that you are talking about ?
and where is the clear last module ?
Unread post by nay-seven » 04 Dec 2020, 10:52
oops, my fault
it's not a module, but inlets in the sampler
Unread post by cmodica » 04 Dec 2020, 13:52
Yes, i know this inlet.
But i try to find a way to clear list in the List Manager and to send the clear list information to the sampler.
that's why it would be great to have a clear list input in the list manager witch can send a clear toggle to the sampler.
Unread post by SylvainT » 04 Dec 2020, 18:20
Clear list.pat
Clear list
(23.05 KiB) Downloaded 627 times
Try this
Unread post by cmodica » 04 Dec 2020, 18:53
I will try and let you know.
Unread post by cmodica » 10 Dec 2020, 16:47
It makes the job. ;)
Users browsing this forum: No registered users and 110 guests
