Synch adjustment
noise2sine
Synch adjustment
Unread post by noise2sine » 16 Apr 2020, 15:03
I'm using a Synch module in my workspace in order to set different tempo in my set.If i'm setting the tempo to 120 with the fader i can see in the top windows that the value of the tempo is 120.01 or 120.02 how can i fix that ?
Thank you :)
Unread post by nay-seven » 16 Apr 2020, 16:22
Have you try the perfect synchro option in the synchro master settings?
Unread post by nay-seven » 16 Apr 2020, 22:12
Can't reproduce
you use the master synchro module and your fader is set to integer ?
