Severals questions
Severals questions
Unread post by grego mondo » 11 Mar 2020, 13:25
Hello all
I have a few questions of differents topics
How do you upload a patch to share (the smart pad adaptation version of Joffo's Launchpad wizard) ?
Is there a cpu difference between 12 busses of floating value and an Array bus of 12 value ?
Does a subpatche add latency ? e.g. the same patching slower in a sub patch (cleaner when you open your patch, easier to re-use in anotehr patch) than directly in the patch ?
Is there a way to use Multiple Variables with more than 3 values ?
Thanks and have a good day (or night)
Unread post by nay-seven » 11 Mar 2020, 15:18
When editing your post, switch to full editor, go to attachement tab, add your file, then click on place inline
Yes a lot, the first solution is around 12 times slower.
No latency, few more cpu just to copy inputs / outputs of the subpatch
Actually no it's impossible, but it a good suggestion
