I'm new to Usine. I find the software very powerful and I would like to use it with Raspberries.
Is it possible to send MIDI data over ethernet from a Raspberry to Usine, please? Maybe using RTP-MIDI?
Another thing: is it possible to send OSC data over wifi from a Raspberry to Usine? Does it apply any latency?
If one or both solutions are possible, are they complicated? How could I achieve this?
Usine for receiving MIDI or OSC from Raspberry?
Can't help you on Rasperry side, but yes Usine can receive RTP-MIDI and OSC messages
for rtp-MIDI it's easy to configure a session on Mac, i know there's a driver from Tobias Erichsen on Windows
you can also check this link about kissbox who work on Usine module.
about OSC , check this Usine video
Thanks for your message. That's good news. After considering your suggestions, I will probably use OSC messages via the local network.
Users browsing this forum: Bing [Bot] and 19 guests
