Hollyhock4 as Slave
noise2sine
Hollyhock4 as Slave
Unread post by noise2sine » 08 Mar 2020, 16:51
Which is the best way to set a whole workspace as slave with an external midi clock ? I have an external drum machine which i want to be the master clock and all the patches in different tracks in the workspace would be slaved to that clock ?
Thank you !
Unread post by nay-seven » 08 Mar 2020, 17:54
Right click on your MIDI in device ( in the device panel) and select "receive MIDI clock"
You can also select " perfect synchro" in the Settings panel of the synchro panel
noise2sine
Unread post by noise2sine » 08 Mar 2020, 23:27
thank you , works perfectly :)
Users browsing this forum: No registered users and 220 guests
