I 'd like to work again with a workspace built in Usine 3.0.185 OSX32, and the memory is very high, around 98%. Of course it stops running.
I deleted tracks but even with 4 audio tracks, the session is still at 82%.
Would you know what to do? Thank you.
memory
Try to disable all racks and open them one by one to diagnostic which one create this
then analyse the same way the faulty rack if you have several patches
do you use plugins ? too much samples? ( are they have been added in memory or on disk ...)
Hello Gwennaelle . I suggest you to update on HH4 . The 64bit version solved all my memories problems.
Users browsing this forum: No registered users and 29 guests
