Grid - curves automation
Unread post by Gilsornette » 28 Feb 2020, 17:04
Am I missing something or it's not possible to drag and drop patches of curves automation on the grid?
Also one question regarding the grid interface: is there a way to customize it, especially the global background and the vertical lines inside the sections?
Thank you
Unread post by nay-seven » 28 Feb 2020, 17:14
Not Possible currently about curves automation, but you can drag any knob/fader with [CTRL+Shift] and create a curve ?
For grid design, same as most of main Usine object, use Shift+right click to add a design tab
Unread post by Gilsornette » 28 Feb 2020, 18:18
thank you for your quick answer!
Creating a curve is not so efficient and smooth than recording automations (fast moves of a fader for example). Or is there a way to draw a curve, like with a pen?
Sorry for this question, but... where should I Shift + right click to add a design tab?
Unread post by nay-seven » 28 Feb 2020, 18:58
No, you can't draw, this will cause too much points and will cost in CPU, but you can right click on the curve and switch to bezier mode ?
About Shift+click , just do it on an empty space of the grid, its settings panel will change and add a design tab
Unread post by Gilsornette » 28 Feb 2020, 19:15
Even in Bezier mode it can be very long and not "human/natural" when you want it during a certain duration.
Do you think it "drag and drop patches of curves automation on the grid" could be a future improvement?
No matter where I shift + click, I'm just accessing to the menu of the sections or lines, not modifying the grid settings panel. Am I missing something?
Unread post by nay-seven » 28 Feb 2020, 19:38
Don't know, you can ask it in the suggestion forum ?
Sorry , my fault, you need to be in God mode ( setup/expert tab) to access this feature
Users browsing this forum: Google [Bot] and 187 guests
