hello
How could I play different medias synchronously on the grid?
The goal is to be able to move around on the grid without losing the synchronization of the elements.
Ideally this should work even if several sections are launched.
There should be a reference time for all medias.
I'm thinking of a counter that memorizes when this or that media is launched. So if I want to move 10 seconds forward or backward, all the media move 10 seconds forward or backward.
I don't know if that's possible as it is. But it would be a super convenient feature.
Thank you. Thank you. Thank you.
Synchronising differents medias on the grid
What do you mean by " if several sections are launched." ?
I'm afraid this is more for the suggestions forum ?
[img]
here is an example of 3 medias on 3 differents sections which are running toghetter .
I wonder if it's possible to move on all medias whithout loosing synchronisation.
ok, but the 3 sections are not running in the same time , only one can, it's your 3 media's who run together
Users browsing this forum: Bing [Bot] and 211 guests
