2Gb wav limit
eimhin
Unread post by eimhin » 27 Nov 2007, 18:36
Can we record to wav64? or somehow get around this limit?
Unread post by senso » 27 Nov 2007, 18:57
Usine is limited to wav32. No way to record 64bits files!
eimhin
Unread post by eimhin » 27 Nov 2007, 20:47
so when recording a set, it will shut off once the WAV files get too big?
Unread post by senso » 28 Nov 2007, 12:11
The limit of windows 32bits is 2.15Gb files(?)
It means around 3H30' for stereo 44100 16bits.
Gives a comfortable margin?
They are no solutions because it's the internal conception of windows.
Just stop rec and restart rec every 3h30!
jean-marc duchenne
Unread post by jean-marc duchenne » 28 Nov 2007, 15:26
Don't you use the Wave_Format_Extensible already for players ?
If I remember well, it can goes up to 4 Gb, and I have and use files that are more than 3 Gb.
Anyway, you can also use the RF64 wave format. The quantization remains 16, 24 or 32 bits :
http://www.ebu.ch/CMSimages/en/tec_doc_ ... -42570.pdf
eimhin
Unread post by eimhin » 28 Nov 2007, 16:43
jean-marc duchenne wrote:Don't you use the Wave_Format_Extensible already for players ?
How the I use that format? It seems I can only save a normal wave file.
I could just stop the recording and start it again. I was just curious because I want to record in 32bit.
So I guess that will be 1h 45mins of time.
moody33
Unread post by moody33 » 28 Nov 2007, 17:09
Usine needs to read AIFF files...
Each time I need an AIFF file, I have to convert it...It's boring !
Users browsing this forum: No registered users and 183 guests
