Playing a video file backward
noise2sine
Unread post by noise2sine » 03 Nov 2019, 15:38
Is it possibe with the video file player to have a fader that can allow to play the video backward to normal ?
Thank you
Unread post by senso » 03 Nov 2019, 15:48
you have to use motion-jpeg codec, then you can access to each frame an any time, and play a video backward with for example a lfo.
you can find a tool to change the compression format in /setup/video/convert-video-to-motion-jpeg
Users browsing this forum: No registered users and 407 guests
