hi, is it so that there is no way to have the sampler loop between start and end pos when sync mode is set to "midi only"?
best regards
antwan
sampler with "midi only"
moody33
Create :
a midi filter connected to your midi input
then add a "create midi " module connected like this:
code 1 and code 2 from the midi filter connected to code 1 and code 2 of the "create midi" module.
Then connected the "stop play" from sampler to " create"s pin of the "create midi" module
Link your midi input and the midi output pin ( create midi module ) to your sampler midi in.
Be careful, it will be Monophonic. I don't know how to do for polyphonic.
- senso
I know that I have to implement a loop position + cross fade as a normal sampler. But the problem is that the Usine sampler doesn't look like a normal sampler but is more designed for live situations!
It's not really a S1000 emulation...
You have to be patient; if you cant wait use a vst like Kontakt, etc.
antwan
that's the thing, the Usine sampler - in all its simplicity - has features that I believe something like Kontakt doesn't. For what I'm doing I also need the rec, save random and next/prev inlets. ASFIK I couldn't do that with Kontakt (correct me if im wrong?)...
I think a couple of more core features and the Usine sampler will reign.
I'll be patient
Cheers,
antwan
I'll be patient
Cheers,
antwan
- senso
I know, you can't do this kind of stuff with other sampler.
The next step is to implement key mapping and loop features.
