MIDI probability gate setup?
tsferro
Unread post by tsferro » 14 Sep 2019, 23:15
is there a way to create a MIDI note probability gate? i.e. take an incoming MIDI note, and allow it pass through based on the user-defined probability of doing so
so if set to "0.10". there is a 10% chance the note will pass through, and at "1.0" a 100% chance...
Unread post by oli_lab » 15 Sep 2019, 00:30
this is the easy way if you don't need the note off :
http://www.sensomusic.org/forums/upload ... 20thru.pat
x.iso
Unread post by x.iso » 15 Sep 2019, 00:42
of course you can. here's an example:
just make sure to set Random module to only generate number on trigger. btw, notice that Random module also got random MIDI note output if you need it. this is for trig/gate situation. as for value randomisation, you can go farther than that, like setting a probability map for values (so your random values are more likely to land on specific spots). solving those problems helps getting better at math, because it's a fun way to solve math problems.
tsferro
Unread post by tsferro » 15 Sep 2019, 02:13
:) big thanks @oli_lab & @x.iso for the detailed setup/info
can't wait to sink my teeth into the logic here - loving how detailed and deep this software is
tsferro
Unread post by tsferro » 15 Sep 2019, 14:11
@x.iso I am attempting to replicate your patch but have encountered a couple small issues
- I don't see any "trigger in" on my "Random" module
- I am not sure how to get "probability" on my fader for "Chng Scale"
EDIT: also not sure how to get my image file to display here!
x.iso
Unread post by x.iso » 15 Sep 2019, 14:52
about image, you've added additional '[' right after img tag, that makes tag invalid.
about Random, sorry, I've just checked and it turns out this option was added in HH4 beta, which I used for example. I'll make example patch for HH3 189 soon
EDIT: in HH3 Random module got 'generate' input as trigger, you just need to set synchro - button as well in it's settings.
x.iso
Unread post by x.iso » 15 Sep 2019, 15:07
here http://www.sensomusic.org/forums/upload ... 0Gater.pat
you can use it as sub-patch in your patch if you want, or just between patches in rack.
tsferro
Unread post by tsferro » 15 Sep 2019, 16:43
thanks vm for the file and explanation
Holz&Strom
Unread post by Holz&Strom » 09 Oct 2019, 10:42
Hi everyone,
sorry if this is a bit off topic, but this is my first post- I'll create a new topic as soon as I'm allowed to. Where in the manual do I have to look to figure out how to patch a simple midi switcher? Here's what I want to achieve: I've got a MIDI foot controller connected to my computer and it's controlling plugin A. I want to hit a MIDI note to re-direct the MIDI data of that controller to plugin B.
Sorry for such a noob question, I guess that's really easy to do, but I've watched the first 10-12 tutorial videos and I'm still not sure where to search for an answer...
Unread post by nay-seven » 09 Oct 2019, 11:33
Hello Holz&Strom and welcome,
Most of the flow's in Usine are compatibles, so you can use a simple data mix dispatcher module to route the MIDI in messages to 2 directions, directly or via MIDI buses if if needed
Add a switch to the select inlet (values 1-2) and create a MIDI learn on it
