Possible to Change the color of a panel text according to a value ?
sguyader
Unread post by sguyader » 11 Jun 2019, 19:24
In one of my patches (B3 organ VSTi), I control the chorus type using a knob. I added 3 panel text boxes to show the position the 3 chorus types I may use (C1, C2 and C3). The icing on the cake would be if I could make the color these panel text boxes change according to the knob value, to simulate highlighting. Is that possible?
Unread post by nay-seven » 11 Jun 2019, 19:36
yes, you can add a patch settings module, a color selector module and your knob ( maybe need to adapt values with a scale)
sguyader
Unread post by sguyader » 11 Jun 2019, 19:46
Thanks nay-seven. I knew it was possible! What Usine HH cannot do? :D
