Patch with multiple piano rolls - can I use them in the rack.
mattox
Unread post by mattox » 19 May 2019, 10:08
I was able to figured out how to make a patch for my Maschine MK3 which is fantastic, it allows me to sequence in HH.
I have a patch with multiple piano rolls - am I able to use those piano rolls in the grid, when I put the patch in the grid this is what I see:
x.iso
Unread post by x.iso » 19 May 2019, 14:22
you can also put midi file into the rack and that will generate patch with piano roll, with midi file loaded. or drop piano roll from library if you need to set the sequence manually. put all Piano roll patches before your plugin patch, then drag them into grid for arranging sequence. whenever patch is not used in the grid (and grid is activated) it is deactivated, so it is bypassed as well.
Take into account that Grid's sections can all have different duration lengths, but same size, so playback appearance is not linear like in regular DAWs. But you can change each section width in size settings.
