Controlling the preset manager via MIDI
benjotrash
Unread post by benjotrash » 12 May 2019, 16:16
Hello...
For my musical project I want to control the drum-sequences live via the korg nanocontrol. Everything works perfect and everything learned by usine is saved in the workspace (Track on/off, FX control, Volume, aso).
Just when I connect the nanocontrol fader to the preset manager, it still works perfect (I can change the presets by fader) - but it is not saved. I tried different ways, but the learned connection is not saved and so everytime I start my project, I have to set the preset change for every drum channel again.
Can anyone help me to solve this? It would make a great music tool perfect :-)
Thanx,
Benjo
Unread post by nay-seven » 12 May 2019, 17:35
Have you test to create (and eventually to share here) a simple patch to check your method ?
for example one knob with 3 states and 3 presets, link the nano...
benjotrash
Unread post by benjotrash » 12 May 2019, 20:21
I am sorry, but I don't get what you mean...
In my rack there is, for example, the midi step sequencer groove from usine and a vst plug for drums. Then I create different presets in the step sequencer and link the preset change (no matter if I use the "<" or the ">" or the pattern list) to the nano (with the other midi devices, too) - it's perfect, works as expected, but when I reload the workspace, it is not linked anymore...
And in the LEARN-list it is linked as "-"...
Unread post by nay-seven » 12 May 2019, 21:23
With Usine there 's always different way to do what you say, that's why i ask ;-)
I can't reproduce this, can you precise the Usine version you use, your OS and version please ?
benjotrash
Unread post by benjotrash » 13 May 2019, 14:10
I use HH3 on different windows systems (1 usine runs on windows vista, 1 on windows 10)...
I'll try to make some snapshots today, but the usine-computers have no access to the internet, so it is a little complicated...
I tried to link it some other way, but cannot find the preset manager in the step sequencer patch...
But everything works fine - when I learn the preset change in the learn list, there the number of the correct CC is shown and the name is shown as "-", but when I reload the workspace, it has vanished from the list.
Unread post by nay-seven » 13 May 2019, 14:30
Ok,
you can also add a patch settings module in your patch and create this to test:
ps: i see you have 2 accounts on the forum and the one with a license has a different name, you can contact me at contact@sensomusic.org if you want i clarify this
benjotrash
Unread post by benjotrash » 13 May 2019, 14:43
I tried to do it like this, just can't find the "current preset num" in the midi step sequencer-patch... I cannot find the preset manager module at all in any patch I use it...
Unread post by nay-seven » 13 May 2019, 15:10
you need to drag the module from the browser/modules/interface control/Usine patch settings
benjotrash
Unread post by benjotrash » 13 May 2019, 15:38
It works!!! I am so happy!!! Thank you very much for the afford... A really great program has become perfect for my needs...
Thank you
Unread post by senso » 14 May 2019, 11:52
there is a bug in presets midi learn save procedure.
will be corrected in the next release
Users browsing this forum: No registered users and 32 guests
