Hey guys, so back at it again and noticed that when i'm trying to use a video player (tried different patch, rack, workspace with same results) leap motion seems to no longer communicate with Hollyhock 3 unless I delete video player module and unplug/plug the usb cable to the Leap. Something to note: I am using a laptop, and not a very powerful one at that. Also to note is that Image Player module seems to be fine and adding video module is fine also, the funky behavior starts when I play the video file. Anyone have similar experience and know a solution that would give me a leap module and video player in one session without video knocking out leap? Thanks in advance.
P.S. Just thought about having a leap input machine and send the vectors through OSC to the "video" machine, but would rather avoid that if possible.
Leap Motion and Video player behavior.
- nay-seven
You don't precise your OS and Usine version, but I can't reproduce this and we never receive feedback in this way, so I'm afraid this come from your configuration, graphic memory ?
- nay-seven
yes, but i suppose you need more graphic memory or maybe updated graphic drivers ?
