Hey All!
So I noticed when you drag a workspace instance of Hollyhock 3 from one display to another, that it changes resolution (say if you have a laptop that's 1366x768 and a TV as a secondary input at 1920x1080). Is there any way I can take that information and use it as an input?
Thanks.
Usine Resolution behavior question.
- x.iso
If you're using Windows 10, then it's probably just automatic DPI scaling, not really controlled by Usine
