my setup consists of HH3 and Mobius ( the software looper) standalone ( as it is still 32 bits just).
I'm using several midi controllers such an Ipad running Mididesigner, a cv to midi and a Keith Mc Millen Softstep.
Everything runs fine, all midi signals are received by Usine.
When I have Mobius running the Softstep is someway not getting to control Usine, while all other controllers do.
Any advice?
Thanks you.
Softstep communication problem
There was Mobius user here in the past, so maybe they can help ?
Hello Unguitar,
I'm not a Mobius user but I had some problems with The Softstep V1 (with the square pads) with Ableton Live and some
Max4L patches. Communication seemed to be lost sometimes between contoller and software. After a (long) while I realized
that the first 8 triggers (notes, cc..) were correctly send, but the next 8 were not send, and only after that everything works correctly.
When opening the soft I always have to send 16 triggers to "initialize" the Sofstep.
I don't know if it's because Softstep software is kind of a Max patch and that I'm using one in Live or if because my OS is Windows, or something else...
Maybe this has nothing to do with your problem, but who knows?
