I'im using the workspace preset mananger and i didn't find how to quantize the preset arrows ? and it's the same for the preset manager inside a patch ?
Any idea ?
Quantizing workspace preset manager
- x.iso
I think it should be under midi/controller tab, but depending on your workspace it might not work properly anyway, as recalling global preset may come with significant latency.
