Return to Zero
noise2sine
Unread post by noise2sine » 31 Mar 2019, 11:58
I'm tweaking the pitch fader during live performance and would like to have a button in order to set the value back to zero ? Any idea ?
x.iso
Unread post by x.iso » 31 Mar 2019, 13:26
If you want it to act like Pitchbend and return to 0 each time you let it go, then try Touch Fader module, there was a mode for that.
But if you just want a reset button, it's as easy as placing a button and wiring it to reset inlet on the fader.
Unread post by 23fx23 » 31 Mar 2019, 15:24
can reproduce a bit what touchfader internally does for this via add a 'from 1 to 0' out out mousedwn output pin back in to reset inlet. each time mouse will be up will auto reset
noise2sine
Unread post by noise2sine » 31 Mar 2019, 18:12
thanks, that's what i was looking for !
