Usine will not recognize Reaktor 5 vsti as a plugin. It detects it, but gives me an error msg when I drag it in.
Can anyone else get reaktor to load?
Reaktor 5 vst won't load
Hello, very strange, because I use Reaktor5 a lot without any problem.
Which release is it?
It's the latest release. 5.11 I think?? It just says that it is not a valid plugin when I drag it into a patch.
No problem:
I've just try the 5.12.009 demo without any problem.
And I use the 5.01 every day!
Are you sure your soft is correctly configured?
Try to reinstall?
Try to reinstall?
Users browsing this forum: Google [Bot] and 126 guests
