audio midi sampler; a few questions
Unread post by Gilsornette » 14 Feb 2019, 12:05
Hello ,
Is the Audio Midi Sampler reading samples only in a mono mode? I can't achieve my stereo sounds to be played in a stereo mode.
Also is it a way to play sounds in loop mode?
Thank you
Unread post by nay-seven » 14 Feb 2019, 14:20
MIDI sampler can read stereo files, yes, try to recreate the module and choose stereo ?
This sampler only answer to MIDI message, so you'll need to create a specific MIDI patch to have loop mode
Unread post by Gilsornette » 14 Feb 2019, 15:13
Thank you for your answer. Ok for the loop mode.
But I still have the same problem, reading stereo files. I've recreated the module, tried to do a new simple patch (Midi in > Midi Sampler > Audio out).
It acts as if channel left was only read in mono mode. And the same sound is correctly played with an audio sampler. Any idea?
Unread post by nay-seven » 14 Feb 2019, 16:07
ok, looks you're right, need to investigate more
Unread post by nay-seven » 14 Feb 2019, 18:01
bug fixed, download the current version 187
Unread post by Gilsornette » 14 Feb 2019, 20:58
Thank you very much!!
All the best
Users browsing this forum: No registered users and 95 guests
