"Quantize" for incoming key commands and midi messages
lalo
Unread post by lalo » 08 May 2006, 08:17
would be nice to have a quantize parameter in the "remote" window for every parameter...
so the message it's only sent to its destination at the next quantization point ...
imagine you are on measure 1 3 1 1 and you want to start playing a sampled loop on the next bar (2 1 1 1)
if you chose quantization as "bar"..your midi ot kkey command will be received by its destination only at the start of 2 1 1 1...
obviously would be nice to have different quantization values :) 16th 32nd 12th etc..etc..
lalo
Unread post by senso » 08 May 2006, 10:33
good suggestion.
I'm gone think about it.
laserbeak43
Unread post by laserbeak43 » 08 May 2006, 13:51
i was actualy gonna see if i can make it with your modules.
i have 2 das off this week at night so i will try when i get back from my day job.
Unread post by senso » 08 May 2006, 15:41
Of course it's easy to do that with modules.
lalo
Unread post by lalo » 08 May 2006, 16:49
yep..it's easy with modules...but if you have to do it for 10 parameters the patch can become messy ;)
lalo
Users browsing this forum: No registered users and 35 guests
