WHERE WOULD i GO TO SOLVE THIS
joojoo1234
My 1010 saffire interface gives me static more and more as I work on the using project and I have to reset it to clear it. It is sitting on my computer - is this the problem as I have killed my background processes... anyone know a good site where these things are discussed. I am a wood and steel musician for the most part.
Well, if you think it's due to positioning, try moving it around the room!
First of all, is all of your gear connected to a grounded electricity grid?
Have you tried using a shielded socket?
What is your setup? What's connected (both in and out) to your interface?
Did you check the cables and the power cords?
Toshiba m40-281, Motu Ultralite, dbx166A compressor, Vassilevsky tap-guitar, M-Audio Oxygen8v2, Usine
joojoo1234
I have got 90% of it gone by loading basic services and lowering my graphics card acceleration and eliminating the firewall on my firewire which I did not know I had... I will look at the other 10%
Users browsing this forum: Bing [Bot] and 286 guests
