vertical scroller
Unread post by Gilsornette » 17 Dec 2018, 18:09
Is it possible to have a vertical scroller in a patch graphic interface?
Thank you
x.iso
Unread post by x.iso » 17 Dec 2018, 18:54
One solution was mentioned here: http://www.sensomusic.org/forums/viewtopic.php?id=6127
there's no scrollbars built in, but you can add faders and use them as scrollbars instead. the trick is with adjusting x/y of the sub-patch with controls that's located in the container. that should work.
Unread post by Gilsornette » 17 Dec 2018, 19:05
Thank you very much. I'll have a look at this. (and wait for the next major release;-))
All the best
