Hey guys,
here's the thing:
- I have a drum pattern outputting Midi-Notes C1-B1.
- All notes are sent to a Midi Bus
- On other racks, I have single drum sounds. Sometimes only one, some have 2-4.
I need some kind of clickable matrix on other racks to isolate only one or a couple
of notes from that Midi Bus stream. (i.e. Rack 2 only gets D1, G1, B1, and Rack 3 gets D#1 and F#1)
I already can do this hardwired, but I'd like this to be dynamic.
My thought was to build something like a matrix where you can click what notes are
passed through the destination rack I just have no real idea where to start.
Any idea?
tL.
Help/Input needed --> Midi note-receiver matrix
Perhaps you need a patch with midi bus receive and wired to Midi matrix and at each output set midi filter to filter specific notes. then copy patch to each rack with drums
Also check if this helps:
MidiReseq addon topic http://www.sensomusic.org/forums/viewto ... ?pid=40508
MidiReseq addon download http://www.sensomusic.org/downloadaddon ... q_v1_5.pat
Aaah, I completely forgot about that one. Yeah, that should help too!x.iso wrote:Also check if this helps:
tL.
Users browsing this forum: No registered users and 35 guests
