ParamMux (Parameter Multiplexer) is a User Module that allows many parameters of different types to be multiplexed over a single data wire.
New in version 2:
- Instant parameter type configuration
- External config file no longer required
- Patchbay and parameter mapping mode
- Parameter map transformation functions (rotate, shift, random, etc.)
- Settings and parameter values now stored in Presets
Full documentation in the ZIP file.
Version 1 add-ons post here:
https://sensomusic.org/forums/viewtopic.php?id=6179
Download link here:
https://sensomusic.org/downloadaddon.ph ... bution.zip
Simon.
ParamMux module new version 2
great !!
Wow, that is crazy useful. Thanks!!!
Anyway to have a Mac version ?
and If it works with HH4, maybe you could add it to the addon manager ?
I'm glad someone is using this. It should work on HH4 but I have not tried it yet.
If anyone can compile for mac let me know and I'll send the source code.
Also feel free to put it in the add-ons manager.
Thanks to Senso for the vital SdkRecreateParam() function.
I have available a class that can be used in a user module to talk to a ParamMux module.
I use it to connect channel strip patches to my midi controller user module.
Users browsing this forum: No registered users and 49 guests
