Piano Roll Event Outlet
Currently the event outlet of the Piano Roll seems to put all the midi events onto channel one only - if you send the event stream from one roll to another you'll see them going to channel 1. For the purposes of manipulating the event information as an array - sorting and swapping values etc, it would be nice if the channel information could be integrated as well (e.g. to keep the drum track information on channel 10 of a standard midi file).
It would also be good if the array could be easily divided into the chunks of midi information - but that's another subject perhaps...
Nobody else interested in multichannel arrays from midi piano-roll?
Apart from building some sort of script to parse midi files I can't see any other way to be able to do fun things with manipulating midi file data outside real-time
I guess it would be useful, although I don't really deal with multi-channel midi files, but I might when dealing with MPE implementation.
Could be easily implemented but the pb is the backward compatibility:
the array size will be 6 length instead of 5 actually if we have
or of course we could merge MSG and CHAN info like:
but in both cases we'll have troubles.
Code: Select all
beat position = 1 (first beat)
event duration = 0.5 (half a beat-8th)
MIDI channel
MIDI message = 144 (MIDI-NOTE-ON)
MIDI data1 = 63 (MIDI note 62 : D5)
MIDI data2 = 98 (velocity)Code: Select all
MIDI message = 144 + MIDI channel -1
MIDI data2 = 98 (velocity)Olivier Sens
I prefer the second solution as it is coherent with the way midi messages are usually done.
I'm not sure i understand the technicalities of backward compatibility, but could a second 'events' inlet/outlet pair be added to the pianoroll - something like 'multichannel events' - which could handle the multichannel midi in either of the ways suggested? or could a switch be added that offers the possibility of switching from a default of merged channels to multichannel with MSG and CHN combined?
If that's not possible how about a Piano Roll substitute module ('Midi Sequence'?) which would add this functionality to the basic piano roll model along with any other improvements that people are looking for? This would avoid any backwards compatibility clash.
keep old module in legacy folder and make a new one !
I was really hoping the new HH would bring a solution to this!
All midi events from a file in piano roll still get squashed into one midi channel when they pass out of the array outlet...
Any chance of a new midi module to get around this?
the solution 1 is implemented in HH4 !
Code: Select all
beat position = 1 //first beat
event duration = 0.5 //half a beat-8th
MIDI channel
MIDI message = 144 //MIDI-NOTE-ON
MIDI data1 = 63 MIDI note 62
MIDI data2 = 98 //velocityOlivier Sens
This is great news! Thanks!
BUT! -
link two piano rolls via array out to array in. put one note on channel 1 and another on channel 2. I can see that the array now has the information in it, unfortunately the piano roll doesn't seem to recognise it properly at the 'array in' - everything on roll 2 is still put on Channel 1. even though if it comes out of the second roll's 'array out' the info is there.
Still the feature is more or less there and that is fantastic!
BUT! -
fixed in the next release.
but it's more appropriate to send bugs reports by mail?
at least faster.
at least faster.
Users browsing this forum: No registered users and 39 guests
