Realtime VSTi and external midi hardware control
Ander
Unread post by Ander » 26 Sep 2018, 05:08
I'm working on a patch with multiple MIDI filters to assign a key range, key transpose, bend off, mod off, note on, and some knobs to tweak sounds.
The MIDI Split module allows to create a key range easily, but pitch bend and other controllers must be merged because the split is applied to all kinds of MIDI messages.
The multifilter module is the other component I'm using to dissable MIDI controllers one by one.
I'm trying to find a way to create complex splits, layers, sample assign, chord assign and real time control and triggering of VSTi and external MIDI hardware to replace a 12U full rack with hardware synths and 2 Muse Receptors.
Any help and ideas are welcome!!!
I need to find a solution my mobility problem as soon as possible.
Ander
Unread post by Ander » 29 Sep 2018, 15:49
Using simoultaneous instances of this free VST on many racks I can achieve about 90% of the MIDI splitting/layering that I need to play live, then I don't have to patch many modules for routing/filtering MIDI mesagges and just use this plugin before the VSTi I want to use.
https://www.eareckon.com/en/products/freebies.html
I hope it can be useful for someone...
Now I'm testing stability and if the CPU processing is not excessive.
Unread post by 23fx23 » 29 Sep 2018, 20:27
good to know, thx for the share!
Users browsing this forum: No registered users and 107 guests
