It would be nice to have array input and output when you use a patch as sub-patch, with all the parameters, in the same way than VSTs.
And it would be cool - for sub-patches and VST's - to export a kind of snapshot of a state (as txt file or csv ?) to backup presets.
for HH4 ?
thanks
array input and output for (personnal) library ?
Not sure it is possible to implement automatic array in and out for subpatch. But it is very simple for you to add array inlet, then array set or display with the good number of inlets. Then use appropriate pass if charge for each module you want to have in that array. Same thing for output, with array ser or display and array outlet.
For snapshot, a polyphonic patch with array set or display.
Soon will arrived script to edit snapshot, but for HH5 I think.
All the best.
All the best.
