Increment Steps
sephult
Unread post by sephult » 18 May 2018, 15:21
I love having the button increment/decrement steps on the faders/knobs, but wouldn't be useful to define the step size of the fader?
I'd like to see being able to checkbox and having the fader follow the step size, not just the buttons.
example of 0.25 step size....the fader would only output 0, 0.25, 0.50, 0.75, 1.
Is there an easy way already to do this minimally?
-s
Unread post by nay-seven » 18 May 2018, 16:12
Yes, use the inc-dec value of the fader ?
sephult
Unread post by sephult » 22 May 2018, 06:45
Hi Nay!
yeah I did do a workaround with the inc/dec buttons ....I get frustrated because I always see the inc/dec value and many times want to use this way...but it doesn't seem to apply to the fader itself when clicked and manipulated with the mouse. For example a minor tuning knob that steps in fixed increments of .2 from 0 to 1 (0, 0.2 ,0.4 ,0.6, etc..).
I can only seem to get inc/dec button inputs of the fader to adhere to the step-value, but it seems logical that there should be option to apply to the fader movement as well.
just something I revisit and run into..... I thought I'd remember to put suggestion in this time. :lol:
-s
Unread post by senso » 01 Nov 2018, 12:08
I think it's very specific and we try to minimize the number of option like that which takes resources on all fader for a small number of concerned controls.
The best way is to create a phantom fader controlled by another and use a mult+trunc+div above?
