Workspace preset question
Pianoscope
Unread post by Pianoscope » 30 Apr 2018, 23:43
Hi just a query about the workspace preset.
The workspace preset does not remember rack activation / enable settings? i.e. if the rack is on or off?
is this correct? This used to work in HH2 but is not working on my version of HH3. Latest version
(edit)
I downloaded the latest version of HH 3.0.169, clean install with no plugins.
Made 4 racks, and 2 workspace presets.
Set workspace preset 1 all racks off, preset 2 all racks on.
When moving from one workspace preset to another the racks status was not saved.
Unread post by nay-seven » 02 May 2018, 17:38
You're right, these elements are not saved, You can workaround this with on/off modules .
You can also ask senso too in the suggestion forum.
Users browsing this forum: No registered users and 452 guests
