I have an older Yamaha keyboard with Midi out, which I want to use with Usine. Strangely, this keyboard is sending an "all notes off" message in addition to the normal note off messages everytime when there are no more notes played. (I have checked with MidiOx). This all notes of message (Controller no. 123) prevents vstI's from entering their release phase (cuts the sound).
Haven't found anything in the keyboard's manual to turn it off...
Any idea how I can filter out this all notes off message without affecting the normal notes off message? Have tried Usine's Midi filter module but this also filters the normal note off msg which isn't usefull for organ etc.
I need to filter all notes off message
You could try to connect the different MIDI parts (channel, data1, data2) to A=B modules, and then connect these to AandB modules, which in turn controls a stop data flow module.
Annoying, isn't it? I used to have a synth once which did the same - a Roland JX3p I think. If the DX7 or TX7 got the all notes off message while sounding, they would emit louds klooiings or something.
Or you can use a simple script to do this
// Filter midi out message
// parameters declaration
var input : Tparameter;
var output : Tparameter;
procedure init;
begin
Input := CreateParam('In',ptMidi);
Output := CreateParam('Out',ptMidi);
SetIsInput(Output,false);
SetIsOutPut(Input,false);
end;
// Global variables
var i : integer;
var nbOfMidi : integer;
var ReceivedMidi : TMidi;
// main proc
begin
nbOfMidi := GetLength(input); // get the number of incoming midi codes
if nbOfMidi > 0
then begin
SetLength(outPut,nbOfMidi); // set the number of output codes
for i := 0 to nbOfMidi-1 // loop for all input codes, for polyphonic data (chords)
do begin
GetMidiArrayValue(input,i,ReceivedMidi); // get each code
if ReceivedMidi.Msg <> 128 then SetMidiArrayValue(output,i,ReceivedMidi); // set output value
end;
end
else SetLength(outPut,0); // nothing received, set out length to 0
end.
I didn't test this, since I'm at work, but it should work....
It filters out on midi channel 1, if you need other channels just change the value 128
k
procedure init;
begin
end;
// Global variables
var i : integer;
// main proc
begin
if nbOfMidi > 0
then begin
do begin
end;
end
end.
k
Since the script is filtering MIDI, I think you should have a counter for the length of output inside the loop. Something like:
I don't remember whether you have to set the required length before you fill the array with data, and I'm at work so I haven't got the time to check either, but you might have to keep the SetLength(outPut,nbOfMidi) part before the loop.
Code: Select all
VAR j : integer;
if nbOfMidi > 0
then begin
j := 0;
do begin
GetMidiArrayValue(input, i, ReceivedMidi);
if ReceivedMidi.Msg <> 128 then begin
SetMidiArrayValue(output, j, ReceivedMidi);
j := j + 1;
end;
end;
SetLength(outPut, j);
end
else SetLength(outPut,0);Bjørn S
Thanks all!
I have found a midi filter plugin that is able to do exactly what I want - filtering out (kill) a specific midi msg! easier for me than do deal with scripts...
If interested it can be found here
http://www.kvraudio.com/forum/viewtopic.php?t=192282
-> midi notch filter
Users browsing this forum: No registered users and 29 guests
