On new computer, having to reenter setup for each Usine session
Newbie Brad
Absolutely not normal!!!!
It means that the setup is
- not saved at Usine shutdown
- or not loaded at startup
Comes from a vista compatibility?
Can you
1) run Usine,
2) enter a valid setup,
3) quit Usine
send me the "Default-settings.ini" file and "LogUsine.log" file by mail at contact@sensomusic.com?
thanks
Can you
1) run Usine,
3) quit Usine
thanks
no problem here on vista famillial premium....
Good news!
Newbie Brad
Please, where do I find the log file?
Also there is a problem between ASIO4All and my systems microphone/linein channels, so I can't pass audio through Usine right now. But I don't think that's Usine's fault, and I've contacted support at ASIO4All.
Newbie Brad
[bump]
log file location?
log file location?
file named " LogUsine.log " in the main dir of Usine....
I was using 3.30 until last night, and I experienced the same problem.
The reason I'm posting this, and I thought nothing of it last night, is that I'm running a 3.0 Intel Core Duo on WinXP. So it's most likely not a Vista problem.
When I get home I'll toss the Default-settings.ini & LogUsine.log on my zip drive and mail em tomorrow.
Newbie Brad
There must be a problem. I have no LogUsine.log file in the main dir of Usine.
check if your Usine folder isn't 'write protected'?
Users browsing this forum: Bing [Bot] and 139 guests
