So I see the cycle length has a max of 16. I'm wondering why the hard limit? Some plugins can follow the bar # and so can only do 16 bars with Usine, before having to cycle back.
Cycle length max of 16
- senso
I can Change it without any problem.
do you want 32, 64, unlimited?
The same for bar length
- senso
Now the cycle length value is unlimited if you use the editor (dbl click) or max 32 if you use the mouse.
The bar length max is now 32 beat / bar.
Next release.
Next release.
- Vincent
Hmmm, I think I shall have to go back to school... BTW have they be informed? We can now build only with prime bars. Great esoteric opportunities.senso wrote:The bar length max is now 32 beat / bar.
vincent michel
composer & novelist
composer & novelist
