usine hollyhock 3.0.162-1/ 3.0.162-2 / 3.0.162-3/ 3.0.162-4 update
Announcements
Unread post by nay-seven » 26 Feb 2018, 15:34
[large]3.0.162-1[/large]
improvements
- Original duration outlet on samplers.
- Improvements of the range-fader UI.
fixed bugs
- Colors inlets settings doesn't work properly.
[large]3.0.162-2[/large]
fixed bugs
- Drop plug-ins on the control panel doesn't work properly.
[large]3.0.162-3[/large]
fixed bugs
- Rename buses doesn't work properly.
[large]3.0.162-4[/large]
fixed bugs
- Devices outputs aren't stored properly
And sorry for these intermediate versions
joffo78
Unread post by joffo78 » 26 Feb 2018, 15:35
cool very speed !
x.iso
Unread post by x.iso » 27 Feb 2018, 02:00
thanks!
Unread post by cmodica » 01 Mar 2018, 19:21
I have 3 problems with this two versions of Hollyhock (162_2 and 162-3) on Mac OSX 10.12.6 with a Macbook Pro Retina.
1 - It can't access to the internet. I read "No access to the internet" on the welcome picture. But Internet is OK on my computer.
2 - Impossible to import an old setup. The window to load an old setup open, but when i click on an old version of HH, nothing happens. I wait, but nothing.
3 - Everything is very slow
So, i still work with the last version that i intalled before, HH 3.0.159_5, and everything is ok.
Unread post by senso » 01 Mar 2018, 21:12
@cmodica
I think all your troubles come from an internet site overload.
solved now.
Unread post by cmodica » 02 Mar 2018, 10:40
thank you Olivier, but it didn't solved.
i delete HH 1.0.162-3, I install again. But the problems remains. No acces to internet and impossible to import old setup.
i tested with HH 3.0.159-5, and it can't acces to internet too. I already have my setup imported, so i didn't kwow about it.
But if it is an internet server overload problem, it seems not solve.
i work often with HH witout internet connection and evreything is ok.
I still play with 3.0.159-5 and i am waiting to solve this problem.
Thank you
Unread post by nay-seven » 02 Mar 2018, 18:18
Have you test recently ? is it ok now ?
Unread post by cmodica » 02 Mar 2018, 21:10
I test now, friday marsh 2 at 21h and it works.
You are right, it should be a problem with the internet site overload. It is a great news, to much sucess :cool:
Thank you very much.
Users browsing this forum: Bing [Bot] and 5 guests
