midi cc mapping curve
Unread post by sm_jamieson » 20 Feb 2018, 11:45
Sorry to seem lazy, but can anyone tell me if there is a module or patch that will allow you to draw a curve and remap midi messages (such as to change the keyboard velocity response curve).
x.iso
Unread post by x.iso » 20 Feb 2018, 13:47
there's a literal mapper curve module, but it's for data, so you need to do some patching to make it work for velocity (or any other parameter)
I think this should work:
Unread post by woodslanding » 29 Jul 2018, 06:50
If this doesn't work for you (it gave me a bunch of stuck notes when using multi-channel sources) try this script:
Code: Select all
// transpose midi example
// parameters declaration
var input   : Tparameter;
var output  : Tparameter;
var velocitiesIN : TParameter;
procedure init;
begin
 Input := CreateParam('midi in',ptMidi);
 Output := CreateParam('midi out',ptMidi);
 velocitiesIN := CreateParam('velocities',ptArray);
 SetIsInput(Output,false);
 SetIsOutPut(Input,false);
 SetIsOutPut(velocitiesIN,false);
 SetLength(velocitiesIN, 128);
end;
// Global variables
var i            : integer;
var nbOfMidi     : integer;
var ReceivedMidi : TMidi;
var newVelocity   : integer;
// main proc
procedure Process;
begin
 nbOfMidi := GetLength(input);  // get the number of incoming midi codes
 if nbOfMidi > 0
 then begin
    SetLength(outPut,nbOfMidi);      // set the number of output codes
    for i := 0 to nbOfMidi-1         // loop for all input codes, for polyphonic data (chords)
    do begin
      GetMidiArrayValue(input,i,ReceivedMidi); // get each code
      newVelocity := round(getDataArrayValue(velocitiesIN,ReceivedMidi.data2));
      ReceivedMidi.data2 := trunc(newVelocity); // calculate vel
      SetMidiArrayValue(output,i,ReceivedMidi); // set output value
    end;
 end
 else SetLength(outPut,0); // nothing received, set out length to 0
end;
x.iso
Unread post by x.iso » 30 Jul 2018, 01:59
in my example perhaps there's Wait module missing for OFF note, to wait exact or 1 more bloc that note ON have to process (since Note ON have more wiring and modules in between actual input and processed output which amount to bloc latency if I'm correct).
Users browsing this forum: No registered users and 93 guests
