Tempo sync and pulling my hair out
kurtjoy
Unread post by kurtjoy » 10 Feb 2018, 12:31
Hi All,
for months I have been trying to get a locked network sync between two copies of HH. I have tried pretty much everything and always get drift within the first few bars making it unusable (even with perfect sync turned on). If try the same using two copies of maschine, even via wifi the sync is rock solid.
Im using HH3 159-5 on two win10 machines connected via ethernet. Ive had a hunt through the addons and tried a few with no luck.
Im almost at the point of trying to link the two via midi clock and see if that works.
Any suggestions would be appreciated.
Kurt
kurtjoy
Unread post by kurtjoy » 11 Feb 2018, 00:40
I should add that I have also tried using rtpmidi over ethernet. It works a lot better, but there is still a lot of drift
Unread post by grego mondo » 11 Feb 2018, 18:11
Sorry, my comment won't help.
I must be missing some thing but every time I tried to sync. as slave an external hardware (arppegio synth) or other computer with another software (e.g. live) I found that Usine master clock was "moving" (not stable)
I saw that on audio recorded (very subtile so you don't feel that the tempo is moving but bad enought that I had to edit my recorded sounds for an electro music album recording ) and I saw it to using Usine midi clock, you actually see the tempo moving on the slave ...
Now I'm never Master sync with Usine when I work with other people, I always let them send a ood clock ...
Users browsing this forum: No registered users and 167 guests
