I have a patch that I am attaching a link to below that works perfectly in Hollyhock 2, but it's record functionality is broken when loaded in Hollyhock 3
https://drive.google.com/file/d/1kRSXx4 ... sp=sharing
If you look at the large XY pad on the left- moving your finger in this pad creates midi out note values, the large square button below the xy pad on the left initiates recording the XY values, tap it once to turn it white and begin recording-tap it again to stop recording-------tap the large square button to the right of the record button to begin playback, tap it again to stop playback
the record and playback function perfectly in Hollyhock 2, but load the same patch in Hollyhock 3 and the record functionality is broken
How can I fix this?
Thank you so much!
XY Record module behaving broken in hollyhock 3, works in hollyhock 2
answered on your other post ( please avoid duplicate post + bug report)
