What does Midi Accumulator do?
maki
Unread post by maki » 15 Oct 2007, 10:43
Is it a midi buffer?
Unread post by senso » 15 Oct 2007, 20:59
yes a kind of buffer.
you specify a buffer length and it records incoming midi events while playing old ones.
Like an endless overdub recording.
You have also a clear button.
Easy to create hypnotic melodies, in a 'steve reich' way (???)
Can be coupled to a midi delay patch (include in the patch) to make very fun stuffs.
maki
Unread post by maki » 17 Oct 2007, 09:15
Is it possible to quantize recording on bar or beat (start and end point sync to host)?
Can buffer lenght be automaticly adjustet while recording? Is it possible to controll start of recording with midi event such sustain pedal on and to stop recording with sustain pedal off?
Unread post by senso » 17 Oct 2007, 09:22
the midi accumulator is designed as a 'midi special' effect.
For your needs use the pianoroll. It has a lot of quantize, start, sync, options.
eimhin
Unread post by eimhin » 15 Nov 2007, 22:07
Where do I find the Midi Accumulator? Is it a module?
Unread post by bsork » 15 Nov 2007, 22:13
The Midi Accumulator is one of six midi effect patches/scripts, and can be found in the Add-ons section. Look for "Midi Scripts Serie I".
Users browsing this forum: Bing [Bot] and 341 guests
