usine hollyhock 3.0.155/156 update
Announcements
Unread post by nay-seven » 06 Jan 2018, 17:51
[large]3.0.156[/large]
fixed bugs
- drop patches or modules on a reduced control-panel
[large]3.0.155[/large]
improvements
- Comma-Text-Editor module
- Reduce patch control panel command
- The mouse wheel can be used to scroll in the settings-panel
- Attack-time parameter in MIDI-sampler module
- Size of control is displayed in the header
- Copy-control-size, paste-control-size contextual menu command
- File-lister module now works for directories
- Improvement of the wheel-mouse behavior and zooming
- -Expert option: disable-mouse-wheel-zoom
- MIDI-learn/active mode "only when patch is on" is now compatible with the patch-on-off module
- Monophonic option in the poly-voice-dispatcher module
sdk
- New sdkDialogInputBox function exported
fixed bugs
- MIDI thru doesn't work properly in piano-roll module
- On a copy/paste of grid elements random curves can be created
- Scrollbar size to 0 just disappeared without any way to restore it
- Various GUI details
Reduced patches example on rack 3:
Unread post by 23fx23 » 07 Jan 2018, 12:28
wouuuouuuu , so coool, was awaiting this one. thanks! :)
Unread post by 23fx23 » 07 Jan 2018, 13:58
trying to add the sdkDialogInputBox,
i do get the the popup dialog and can enter text, but don't manage yet to get/use the variable once pressed enter, (it trace nothing too).
any clue how to use it if near the place olivier?^^
(used like this:)
Code: Select all
	AnsiCharPtr test;
        test = sdkDialogInputBox("Enter value: ", "value:", "no name");   ///caption,prompt,dft
	sdkTraceChar(test);
sephult
Unread post by sephult » 07 Jan 2018, 20:03
Had to tease too didn't you 23fx23 :)
Love your interface.
-s
Unread post by 23fx23 » 07 Jan 2018, 20:14
hehe coming soon coming soon, but that 'enter numeric values' remain at top of my decreasing todo list^^
x.iso
Unread post by x.iso » 08 Jan 2018, 02:31
Unread post by senso » 08 Jan 2018, 08:04
@23fx23 I think it's connected to shared memory.
Will be solved in the next release. 157
Unread post by 23fx23 » 08 Jan 2018, 11:45
yess ok cool thanks :)
Users browsing this forum: Bing [Bot] and 6 guests
