using an external library
Unread post by oli_lab » 04 Jan 2018, 21:35
I'm a little bit lost...
I'm trying to include a lib (swarmz.h) into the code of a new module.
did this in my .h file
#include "swarmz.h"
using namespace sw;
looks ok.
and then this in .cpp :
// define our swarm members
vector<Boid> boids;
boids.push_back(Boid(Vec3(1, 0, 0), Vec3(1, 0, 0)));
boids.push_back(Boid(Vec3(1.5, 0, 0), Vec3(1, 1, 0)));
boids.push_back(Boid(Vec3(1, 0.5, 0.5), Vec3(0, 1, 0)));
boids.push_back(Boid(Vec3(4, 4, -2), Vec3(1, 0, 0)));
//create the swarm!
Swarm swarm(&boids);
if I put the latter in void boidsOli::onInitModule
it compiles ok, but then when I put :
swarm.Update(deltaSeconds);
in onProcess()
it says class Swarm has no member swarm
hum ...
thanx for your help
Unread post by 23fx23 » 04 Jan 2018, 21:49
note sure shouldn't the swarm object be created in the .h too?
