Apply Poly and layout
Ken29
Unread post by Ken29 » 14 Dec 2017, 23:15
Hi Guys,
Each time I apply poly (not apply and reset), the lovely layout which took so much time to set is squashed into a pile of icons in the corner of my patch. Is there's any way to avoid this ?
Best
Kenan
Unread post by oli_lab » 14 Dec 2017, 23:39
you can specify the position of the panel directly to inputs of the modules. then use the poly number module to shift the panels from one voice to another
Ken29
Unread post by Ken29 » 27 Dec 2017, 17:04
Thanks Oli,
Thanks for your answer. I finally did it another way, I created a sub-sub patch in my sub-patch, I design the layout on the sub-sub patch and then I force reoganization on the sub patch...
Kenan
Unread post by woodslanding » 30 Dec 2017, 05:36
well, there you go. Never thought of that. I might be able to use that, thanks!
Unread post by oli_lab » 30 Dec 2017, 09:53
plz share !
Users browsing this forum: No registered users and 125 guests
