Ctrl-Click-Hold-Drag (Duplicate Module)
sephult
Unread post by sephult » 11 Dec 2017, 17:31
I've been using some different UI designers.
One of the things I think I miss when I am using Usine is Ctrl-Click-Hold-Drag to duplicate the object.
Would be cool if you could do this in the patch editor window to duplicate modules.
-s
Unread post by oli_lab » 11 Dec 2017, 20:21
+1
ctrl+c then ctrl+v is not bad but...
x.iso
Unread post by x.iso » 11 Dec 2017, 23:51
well, it's half-implemented, since it actually does work for duplicating patches to other racks.
Unread post by senso » 30 Dec 2017, 14:02
not so simple to implement, let's still use the old style ctrlV for the moment.
sephult
Unread post by sephult » 30 Dec 2017, 15:52
Sounds good, I have no qualms. Just something I picked up.
Maybe a design upgrade in the future.
-s
Users browsing this forum: No registered users and 74 guests
