documentation for SDK
Unread post by sm_jamieson » 01 Dec 2017, 17:34
Some of the SDK techniques are covered by the example modules, but other are undocumented. Please can the SDK documentation include and example of how each function is used in code.
For example, I am unable to work out how to use sdkAddSettingsLineString(), or whether there is a bug, as the only hint is in the header file, which does not contain sufficient information.
See this thread for details:
http://www.sensomusic.org/forums/viewtopic.php?id=5999
Unread post by sm_jamieson » 13 Dec 2017, 02:07
Well I worked it out anyway - see other thread for details.
Unread post by senso » 30 Dec 2017, 14:04
You're right. The documentation is an hard job. I hope to have time for that soon.
